Re: stuck cub
Posted by old on October 07, 2008 at 09:27:58 from (4.244.90.245):
In Reply to: stuck cub posted by seabee (Ga) on October 07, 2008 at 08:56:50:
The 2 things are most likely 2 different problems and need to be worked on, on there own and while you wait on the ATF to do its job you need to look at lubing up the control and maybe even drain the hyds. system to make sure it doesn't have water in it
