Re: stuck cub help needed
Posted by old on October 07, 2008 at 09:45:19 from (4.244.90.245):
In Reply to: Re: stuck cub help needed posted by 7lazy77 on October 07, 2008 at 09:37:07:
Automatic transmission fluid=ATF. Yes its a good thing to pour into the cylinders of an engine that has sat for a long time. It will prelube the cylinder walls, help brake down any rust that may have formed and just plain loosens up the rings etc. You can also mix it with gas to help clean up the engine, 1qt to 5 gal of gas will help clean out carbon deposits and loosen things up that maybe sticking. Ya you can also use MMO but ATF cost less then half and does pretty much the same thing just doesn't smell as good
