Re: Char lynn torque generator identification
Posted by PaulW_NJ on October 07, 2008 at 18:39:52 from (96.225.89.253):
In Reply to: Re: Char lynn torque generator identification posted by ytr1903 on October 07, 2008 at 03:18:50:
Tom
That blowup is from an IH parts manual. I don"t know for sure that the one I have is a #101. although I blew up another photo I have of the end of the unit and I believe I can make out "101".
I can also scan the parts list that goes with it, and that will provide all of the IH part numbers. But most importantly, there is a 7 page rebuilding procedure in the IH Blue Ribbon Manual GSS-1278, Hydraulic Valves and Systems.
I rebuilt my power steering unit because of leaks, and it involved a seal and a couple of O-rings. You can remove the two "ends" and get access to the seals without disassembling the entire unit, and possibly disturbing the closely machined lobe surfaces.
If you"d like, I can scan those pages and email them to you.
