Re: Plow , Cultivator or What?
Posted by konstan on October 07, 2008 at 19:56:42 from (204.26.91.110):
In Reply to: Plow , Cultivator or What? posted by EDW on October 07, 2008 at 18:05:29:
Four implements I use the most, in this order
disk - good all around tillage implement, and many are pull type, no need for three point, but you would need hydraulics to lift it up and drop it
harrow - an amazingly useful implement. i have a spring-tooth harrow and i absolutely love it. uses range from harrowing after disking to even things out to harrowing the seed if you broadcast it
Lister - like a plow but instead of turing the ground over just leaves two open furrows. Good to plant and then dig up things like potatoes and garlic.
plow - break up new ground, make terraces, move dirt around... i use my plow a lot more for dirt work than for farming.
