M-valve adjustment questions
Posted by Dan32 on October 07, 2008 at 20:08:29 from (72.69.148.47):
Couple questions about setting the valves on an M. First, does anybody sell a rubber type valve cover gasket? All I could find are the cork ones but I thought a rubber one like they have for the Chevy 350s would be the way to go.
Second, what do I set the valves at when the engine is cold? I already had the valve cover off once now and it leaks like a seive so I cant run it again to warm it up.
Third, whats the tube that runs from front to back over top of the rocker arms? Is it an air tube or a water/antifreeze tube? Almost looks like an air tube and I either have a small dent or a rust hole near the front of the motor. Is the tube replaceable or repairable? If its a water tube, can I solder it like a copper pipe in a house?
Is there anything else I should look for or at while I have the valve cover off? It looks pretty clean but I am new to the tractor engines.
Thanks for the help.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
