Re: Charlyn Hydraulics?
Posted by Gene Bender on October 08, 2008 at 08:21:10 from (67.55.226.167):
In Reply to: Charlyn Hydraulics? posted by Red Dave on October 07, 2008 at 15:15:04:
I use two of them both on the B Farmall. I weld brackets so they set off to the left of the pto and use 50 roller chain. I slow the unit down by using 3-4 teeth less on the pto. Unit has plenty of flow and pressure. It will power two 3in cycl plenty fast enough. They have a web-site for the parts book and other info.
