Re: stuck H advice
Posted by RustyFarmall on October 08, 2008 at 08:33:23 from (209.152.78.71):
In Reply to: Re: stuck H advice posted by old on October 08, 2008 at 08:14:23:
Another trick is to engage the hand crank onto the crank shaft and then hang a heavy weight on the hand crank. A rear wheel weight works good. A length of chain will allow you to position the weight close to the ground so if it falls nothing will get damaged. Just let it hang there for a week or so until one day the weight will be on the ground.
