There's still a problem. Most likely the generator is not working. However could also be the generator IS working but the ammeter is wired up wrong and is not reading correctly. (With the engine running at speed, if the system is charging the ammeter should swing far to the right of center with the lights off, and a little to right with the lights on).
Do you have an accurate DC voltmeter? If so take a reading across the battery posts with the engine running at speed. If the system is charging you will see 7.0 to 7.5 volts across at the battery. Less than 6.6 volts means the battery is being drained.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
