Posted by Andy Motteberg on October 08, 2008 at 19:05:12 from (4.143.223.16):
In Reply to: carburetor adjustment posted by hank woll on October 08, 2008 at 15:00:53:
Hello Hank, To adjust the idle adjusting screw, turn it in until lightly seated and open it 1 turn. Start the engine and operate it at fast idling speed (without any load) until thoroughly warm. While the engine is running at fast idle speed, it is advisable to screw in the throttle stop screw a few turns to prevent the engine from stopping when the throttle is closed. Now close the throttle by pushing the throttle lever all the way forward. The engine will then be idling at a fairly high speed and the throttle stop screw can be backed out a little at a time until desired idle speed is obtained. If the engine misses or or rolls while backing out the throttle stop screw, the idle adjusting screw may be adjusted either in or out until the engine operates smoothly. Speed up the engine for a few seconds; then recheck the idle adjustment. A slight adjustment in or out will give the smoothest idle. NOTE: If your H has a magneto, the engine should not be set to idle so slowly that the impulse coupling will trip continuosly. To adjust the main fuel adjustment screw, first warm up the engine. To regulate the main fuel adjustment, advance the engine speed control lever to fast idle position and turn the main fuel adjustment screw clockwise until the fuel flow is shut off and the speed of the engine drops because of the lean mixture; then open until the engine runs smoothly. After the engine has been put under load, readjust the the main fuel adjustment if necessary. Always adjust so that the engine operates smoothly with as lean a mixture as possible.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
