Re: I need a Farmall B block
Posted by Dave_Id on October 09, 2008 at 05:19:10 from (24.196.57.226):
In Reply to: I need a Farmall B block posted by Talon on October 08, 2008 at 19:10:17:
I'm assuming that the crack you have is behind the carb on the water jacket. Some of these cracks can be repaired. As long as the crack doesn't go across the top of the block between cylinders, it should be able to be repaired. Check the archives on this subject. Some repairs can be done with J-Weld. Check the crack out carefully.
