Re: Primer, why is it doing this?
Posted by glennster on October 09, 2008 at 06:55:23 from (99.131.129.77):
In Reply to: Primer, why is it doing this? posted by Andrew Z on October 09, 2008 at 06:43:51:
could be a number of things that caused it, also depends on what type of primer you used. sounds tho like the primer either wasnt reduced enough, or too fast of a reducer. did you run the primer thru a paint filter when you loaded the gun? i would sand the primer down and shoot another coat over to even it out, block it again and then shoot it. i am assuming you used the right gun pressure .
