Re: Static Timing a M
Posted by ScottyHOMEy on October 09, 2008 at 11:46:19 from (70.105.230.84):
In Reply to: Re: Static Timing a M posted by rustred on October 09, 2008 at 08:50:58:
The timing light works because it fires the light from the juice to the plug, rather than from juice going through the points. One of the great secrets of old ignitions is that they don't make the spark when the points are closed, they make the spark when the points open, causing the electro-magnetic field that was building up in the coil (while the points were closed) to collapse and discharge the voltage for the spark.
In the old days, timing lights used to come with a little springy thingy, would remind you of a short piece of one of those simple coiled screen-door springs, only smaller in diameter and actually different sizes at the two ends. The bigger end fit over the terminal on your plug, and the smaller end into the terminal on your plug wire, and you clamped onto the springy thingy with the cable from your light that would trigger the bulb to fire. These newer fangled ones use the clip that just wraps around the plug wire to sense the current and trigger the bulb. I don't think they work as well on the old-style wires -- they won't fire off time, but they don't seem to fire as reliably as the old direct connections.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
