Re: Static Timing a M
Posted by Bernie Steffen on October 09, 2008 at 17:33:01 from (12.205.165.134):
In Reply to: Static Timing a M posted by labman98 on October 09, 2008 at 07:28:34:
The best way I have found to time my Farmalls is to use a dial back timing lite. Set the idle on the tractor as slow as you can. Set the timing lite to zero. Adjust the distributer till the light flashes on the first mark. Set the timing light to 20 degrees advanced. Speed up the engine. Light should still flash on the first mark. This method also checks the advance in the distributer.. Luck Bernie Steffen
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
