Re: Farmall M wont shut off
Posted by James Rumph on October 09, 2008 at 17:45:16 from (24.192.125.175):
In Reply to: Farmall M wont shut off posted by Dalton S. on October 09, 2008 at 16:26:23:
I had the same problem with mine !
The timing was set correct , it had 110 octain fuel in it and everything was new and tuned on the dyno.
It turned out that inside the voltage regulator there is two sets of contact points that the correct gap must be set.
After prying all the tabs open on the brand new "American made" one that the one set of points was loose and open to far. The correct gap is .020.
After setting the gap it shuts off perfect every time.
We chased this problem for a while, it does have something to do with feed back. If i tried to turn it off at 900rpm or more it wouldn"t shut off, but if you ideled it down as loww as possible it would.
It did this on a hot or cold motor.
I went as far as buying a brand new wireing harness and having the generator rebuilt.
