Re: Farmall M wont shut off
Posted by John Bentley on October 09, 2008 at 18:14:40 from (70.119.35.69):
In Reply to: Re: Farmall M wont shut off posted by tn terry t on October 09, 2008 at 16:32:40:
Tn Terry is right on the money. Install one ohm light or diode in-line, along with a small switch. When you shut off your ignition switch, then switch your diode switch. The engine will stop. When you get ready to restart, switch the diode switch back as well as your ignition switch and you're back in business. Note: Until you get used to this, keep an eye on your ammeter. One way you switch the diode the battery charges quite a bit, the other, much less. You will get used to it.
