Re: Farmall M wont shut off
Posted by old on October 09, 2008 at 19:30:59 from (4.244.186.248):
In Reply to: Farmall M wont shut off posted by Dalton S. on October 09, 2008 at 16:26:23:
That's called dieseling caused by carbon build up in the cylinders or timing being off. If its carbon theres a few ways to fix. #1 is to add a qt of ATF to 5 gal of gas and run it. #2 is to pull the air intake tube off and when its running spray a water mist into the carb. But of course it would help if you can explain it better because any one of use could have the answer because you do not explain things well
