Re: Static Timing a M
Posted by Bob on October 09, 2008 at 20:51:30 from (69.178.228.68):
In Reply to: Re: Static Timing a M posted by rustred on October 09, 2008 at 17:36:56:
"the condeser stores the spark till the points open"
That's 100% WRONG. When the points are closed, both sides of the condenser are at ground potential, and NO energy is stored in the condenser while the points remain closed.
The energy that makes the spark is stored in the coil, as a magnetic field in it's soft iron core.
When the points open, there's no longer current flow through the coil's primary, so the magnetic field collapses making the high-tension spark.
The condenser's main function is to prevent arcing at the points as they open, which would dissipate energy as HEAT, rather than sending a HOT spark to the plugs.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
