Re: Farmall M wont shut off
Posted by mkirsch on October 10, 2008 at 06:04:59 from (64.80.108.53):
In Reply to: Farmall M wont shut off posted by John M on October 10, 2008 at 03:10:27:
That engine has to be carboned up REALLY BAD for it to "diesel" on indefinitely.
You also have to WORK the engine to get the carbon hot enough to ignite the fuel for "dieseling" to occurr.
If you're just firing up the tractor cold, and it's doing this, the alternator is backfeeding the coil and you need to add a diode.
At idle, the alternator isn't providing great voltage, which would explain any erratic running.
