Posted by Andy Motteberg on October 10, 2008 at 12:39:43 from (4.143.220.196):
In Reply to: F-20 clutch problem posted by Pete in Holland, MI on October 10, 2008 at 12:11:58:
When I bought my F-20 the clutch pedal did not work right, I removed the clutch inspection cover on the bottom of the tractor and found that the clutch housing was packed full with a mouse nest. I cleaned all that junk out and adjusted the linkage and the clutch seems to work fine now. If the linkage is not the problem, it could be a worn clutch.
Today's Featured Article - The Engine Rebuild Kit - by Curtis Von Fange. I always liked engine rebuild kits. They have all the replacement parts for overhauling an engine without going to the store to get gaskets, special measuring tools, or miscellaneous parts. They come neatly packaged, clean and tidy. But it's important not to let that packaging lull you into a false sense of security. The appearance of matching sleeves, pistons, rings, and bearings can cause frustration and agony if not properly measured and installed in a workshop environment. Following c
... [Read Article]
Latest Ad:
[More Ads]
