Re: What's it worth?
Posted by Andy Motteberg on October 11, 2008 at 14:48:43 from (4.143.216.183):
In Reply to: What's it worth? posted by Ami on October 11, 2008 at 14:38:47:
I can't give you an exact value, but if the tires are good and sheet metal is good, transmission works good, I'd say around $800-$1200. If it has options like wide front, fenders, etc, it would be worth more.
Andy.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
