Posted by P and R Pete on October 11, 2008 at 16:09:35 from (66.33.250.76):
In Reply to: C Pulley Removal posted by IndianaRed on October 11, 2008 at 09:52:55:
I have a SA, if they're similar.
I used a bearing splitter behind the pulley, cinched down tight, and then a large two-jawed puller on the bearing splitter.
My pulley looks like this.
The end of my crank is threaded, and I didn't want to bung up the threads, so I threaded a long bolt into the end of the crank, and drilled a 'divot' on the center of the head of the bolt, so the pointed end of the puller would nestle there and not want to 'walk' around on the head of the bolt. I heated the pulley with a propane torch (all I had) until it was too hot to touch, and then cranked away using a hardened socket like for an impact wrench. SOB didn't want to move, but then suddenly did with a loud *snap*. Thought I broke my wrench, but it was just the pulley starting to move.
The head of the bolt fit through the pulley, so I got the pulley off over the bolt, and then unscrewed the bolt from the crank.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
