Re: Re: Re: Re: How many plow bottoms can a Farmall M-TA pull?
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by medfarm on March 25, 2000 at 23:05:02 from (209.162.36.218):
In Reply to: Re: Re: Re: How many plow bottoms can a Farmall M-TA pull? posted by RAW in IA on March 25, 2000 at 18:45:53:
I have agree with extended use of the TA. On the 1566 (a three speed main box), the TA has to be used quite often to get the correct ground speed. The TA lever needs to be moved as a gear shift lever, not as a clutch.
Post A Followup
: Re: Re: Re: Re: Re: How many plow bottoms can a Farmall M-TA pull?
