Re: C Pulley Removal
Posted by ScottyHOMEy on October 11, 2008 at 19:45:25 from (71.241.207.71):
In Reply to: C Pulley Removal posted by IndianaRed on October 11, 2008 at 09:52:55:
The pulley is a press fit onto the crank. As far as removal the others have gien you good quidance.
The threads you may see in the center of the front of the crank, though the hole in the middle of the pulley, can be used to pull the pulley onto the crank, but aren't really necessary of you heat the pulley to about 250 or 300 degrees in in an oven and slip it onto the front of the crank.
