Re: Shifting into 5th Gear on a Farmall
Posted by KEM on October 11, 2008 at 21:48:20 from (12.183.85.13):
In Reply to: Shifting into 5th Gear on a Farmall posted by Bucky on October 10, 2008 at 22:05:54:
What works best for me is full speed in 4th, then clutch, push throttle to idle and pull gear lever into neutral all in one motion...double clutch with throttle at idle then drop into 5th. Let the clutch out and advance the throttle. Doing this will usually allow it to drop right into 5th without clash. Engaging the clutch with engine at idle will allow you to use the engine to pickup speed rather then slipping the clutch.
