Re: motor exchange
Posted by Hugh MacKay on October 12, 2008 at 02:14:23 from (216.208.58.180):
In Reply to: motor exchange posted by Dale in Ar. on October 11, 2008 at 18:50:13:
Dale: If the C-135 comes from a 404 it will a direct bolt up. You may have to make minor modifications to fan and shroud as well as air breather hook up.
If the C-135 comes from a 330 or 340, you will have to add drilling hole in end of crankshaft for Super C pilot bushing.
I doubt if you can use C-153 from a 444, the exterior of that block is cast to fit British designed tractors. The C-153 from a 504 will need all of the above, plus you have to change engine front cover.
