Bob's comment is very important, A Mag needs a switch that grounds when shutting it off, a distributor sw is open when shut off. One can ground one terminal on the original switch, removing the wire from the amp meter of course, to make the old switch into a grounding switch, but it will stop when out, and run when in. A SPST toggle sw, or on off key sw with one terminal grounded will work. JimN
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
