Re: Farmall 450 engine
Posted by RN on October 12, 2008 at 11:33:14 from (75.128.248.96):
In Reply to: Re: Farmall 450 engine posted by Janicholson on October 12, 2008 at 07:43:57:
One possible dispute- shutdown switch to gasoline? Archives quote old manuals as saying switch to gasoline to shutdown at idle so diesel fuel is purged from cylinder for next start, then shutoff engine after idle couple minutes, then set controls back to diesel to let third valve close/reseat to prevent valve warpage. Early MDs drill- using it meant long life, not doing it meant hard starts, not resetting to diesel after stopping engine was the valve problem. RN
