Re: F-20 mag question - - tractor won't shut off
Posted by the Unforgiven on October 12, 2008 at 12:50:01 from (66.146.251.208):
In Reply to: F-20 mag question - - tractor won't shut off posted by Pete in Holland, MI on October 12, 2008 at 11:47:49:
Do you see the little bump inside the case at about 3 o'clock, there is a little finger on the breaker plate, down near the bottom, that contacts this bump and grounds the points in the up position. I imagine it might not be making a good connection, but the finger is usually missing if it won't shut down. Look in one that works and it's pretty obvious.
