Re: Ceramic Resistor on an H
Posted by John T on October 12, 2008 at 17:06:34 from (66.244.97.31):
In Reply to: Ceramic Resistor on an H posted by Doug Kieta on October 12, 2008 at 11:30:10:
If its now 12 volts (and especially if it has a 6 volt coil) I agree with Old, its likely an ignition ballast resistor that reduces the 12 volts coming down from the ignition switch down to 6 volts for the 6 volt coil. I call them the "bathtub" type they are white/cream porcelain/ceraimic units with a wirewound power resistor inside and are around 1/2 x 1/2 x 2.5 inches or so and would measure around 1.25 to 1.85 ohms or so between the terminals. They wire in series after the ignition switch but before the coil, piece of cake......
Can you tell if its a 6 or 12 volt coil and a 6 or 12 volt genny etc??
John T
