Re: SuperMTA problem
Posted by Red Mist on October 12, 2008 at 19:00:39 from (67.142.130.19):
In Reply to: SuperMTA problem posted by HicksDale on October 12, 2008 at 18:44:38:
since it is 12V, it is probably negative ground; you have probably done no damage. The smoke if probably from dirty terminals causing a lot of resistance. Clean everything and try it again.
Having said that, if it has a 12V GENERATOR, it might still be positive ground. If it has an alternator, it is most likely negative ground.
mike
