Re: SuperMTA problem
Posted by Andy Motteberg on October 12, 2008 at 19:18:41 from (4.143.220.197):
In Reply to: SuperMTA problem posted by HicksDale on October 12, 2008 at 18:44:38:
It would have been positive ground when it was new, but if it was switched to 12 volts, it might have been switched to negative ground. Look at the ignition coil, there are 2 wires attached to it. Is the wire connected to the distributor connected to the positive or negative terminal on the coil?
