Re: Can holes be drilled in a Genny...
Posted by Gene Bender on October 13, 2008 at 03:14:11 from (67.55.226.167):
In Reply to: Can holes be drilled in a Genny... posted by Mike CA on October 12, 2008 at 22:47:04:
If you want to be correct get the correct generator as the one you have mite not operate with the cut-out.
