Does it improve the way it run if you choke it when that happens or does it make it worse?? If it improves that means it is running way to lean if worse to rich. Either way it sounds like you have a clogged up carb and you may need to rebuild it. If its the type of carb with out an adjustable main jet some times you can remove the cap over the main jet and the drain plug and spray carb cleaner into the main jet and that will fix the problem but only about 50% of the time will that work but its a cheap fix if it does
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
