You do not need to access the flywheel to do this. You do not need to even bend over...better for us old guys. Just put it in neutral, ignition OFF!, and grab the fan blade with one hand, and push inward on the fan belt with the other, now turn the fan blade. The engine will turn. If it seems to be "locked up", then it is proof of the bad starter/bendix idea. If you reverse the direction of the fan turning you just did, it will push the starter bendix back out. This has been a frequent problem with my 300U, but I never had it happen with the 340U.
I suspect that the end bushing on the starter shaft is worn, the bendix teeth worn, and the ring gear teeth are also worn. Some day I will split it and fix the problems.
Another way to free it up is to put the tranny in 5th gear, ignition OFF, and rock the tractor back and forth. If you listen carefully, you can hear the bendix pop out of the ring gear.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
