Re: Plumbing loader to 560....
Posted by J.J. from Afton on October 13, 2008 at 11:11:58 from (139.225.250.243):
In Reply to: Re: Plumbing loader to 560.... posted by Clefus on October 13, 2008 at 08:12:46:
Probobly the easiest and simplest way would be similar to Charles layout. Run the line from the pump to a set of valves for the loader than from there to remote vlave block on the tractor. Than youd just have to have a dump line running from the loader valve assembly back to the resivoir using the fitting on the cover that you mentioned.
third party image
