Posted by Red Mist on October 13, 2008 at 16:13:21 from (67.142.130.38):
In Reply to: Super C sputtering posted by JakeBrakeIH on October 13, 2008 at 12:03:32:
It can also be caused by improperly set/worn points. It can also be caused by a worn distributor - meaning too much side-to-side play in the distributor shaft, thus making it impossible to ever get the points set properly. Take the cap, rotor and dust cover off the distributor and see if you can wiggle the shaft side-to-side. If there is much movement, it will never stop "sputtering" as you say, until the distributor is repaired or replaced. Good luck. mike
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
