Re: A/B/C transmissions shift backwards...
Posted by Hugh MacKay on October 13, 2008 at 16:46:06 from (64.228.11.73):
In Reply to: A/B/C transmissions shift backwards... posted by mkirsch on October 13, 2008 at 11:43:59:
mkirsch: I farmed a lot of years, always had SA, 130, 300 and 560. Quite often I switched from 4 speed to 5 speed and vice versa several times per day. Never found it to be a great challange, making the switch.
I will not say all, but most transmissions I've encountered if it has even number of gears including reverse, you'll find reverse opposite first. If it has odd number of gears including reverse it will be forward gears paired up and reverse off by itself. Been true in any cars, trucks and tractors I've encountered.
