l938 F-14 Farmall camshaft problem?
Posted by Stan Bainter on October 13, 2008 at 17:14:27 from (76.29.129.96):
Running at full throttle it starts running out of fuel. The fuel pump was rebuilt and when manually operated shoots gas about 8 or 10". With the fuel line disconnected from the carb the plugs removed only a dribble of gas comes out of the line when cranking fast. A new push rod does not help. The push rod only moves a bout 1/4 inch in and out. Can the push rod be lengthened or should we try and locate another camshaft? Any body rebuild these? Advice appeciated.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
