governor setting on H
Posted by Guyzoo on October 13, 2008 at 18:34:10 from (198.164.97.38):
Hi, since i have my H it always runs rich at idle. I tried advancing, retarding the timing with little or no effects. I adjusted the carb like it is supposed to: main needle two to three turns out and the mixture idle untill it runs smooth on idle. so I am suspecting the governor adjustment
Now, I noticed that even if I unscrew the idle adjusting speed screw all the way out the engine still runs at about 500 to 600 rpm. I removed the cover in front of the governor and found two adjusting screws that looks like the ''stops'' for the low and high speeds of the engine. If I unscrew the upper screw in the gov. ( the one that stops the shaft from turning when the throttle is at idling position) the engine still runs at 500-600 rpm with the idling adj on the carb fully out.
I noticed an adjustment on top of the governor under the little cover with the steel pipe attached to. Could this be the trouble?
I guess a carb and a tune-up kit would help too
Thanks in advance for any info and opinions
