These motors, in my experience, will fire right off after a good rebuild. They do require to be worked to seat the rings properly, but really don't need to be wound up hard to get or keep them running.
That said, most of us, as long as the teeth are in place on the gears at the front, use the same ones that were there, but there is enough slop in them from the years of use that there is often some benefit to doing a little timing by ear once it's running, as those gears, from the crank to the cam to the governor/distributor shaft, will have developed some slop. That's where the danger of retarding the timing too far comes in.
As a last step, after retorquing the head and running the valves after you've had it running well, I'd suggest you re-check the static (dead-stop) timing against what was done with the motor running.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
