Re: Farmall C wont shut off
Posted by rustred on October 13, 2008 at 21:55:21 from (209.115.232.65):
In Reply to: Farmall C wont shut off posted by Bob S. on October 13, 2008 at 17:27:24:
i also worked at a GM dealership as mechanic in late 70s and 80s . to cure dieseling the idle had to be slowed down. thats why GM had electric idle solenoids on the carburators. you set the carb idle screw so the throttle plates were completely closed or next to it then the idle was adjusted with the electric solenoid adjustment to get your idle speed. then when you turned the key off power was cut to the solenoid which resulted in the throttle plates closeing preventing dieseling . example the 427 was bad for that. it was more of an idle thing than timing . timing was checked also and if anything it would be set a couple degrees to the retarded side from the factory setting. and yes advancing timing increases engine RPM.my experience with dieseling is your idle is set too high. slow it down and problem solved.
