Re: Can't start Farmall C after carb cleaning
Posted by RustyFarmall on October 14, 2008 at 10:27:58 from (209.152.78.71):
In Reply to: Can't start Farmall C after carb cleaning posted by SDP1 on October 14, 2008 at 10:16:05:
The needle valve is sticking. Take the carb apart again, remove the float, remove the needle, and spray both the needle and the seat liberally with spray carb cleaner. Blow them dry and reassemble. Double check the float height while it"s apart. Should be good to go.
