Re: Is it safe?
Posted by CNKS on October 14, 2008 at 11:21:35 from (216.144.104.128):
In Reply to: Is it safe? posted by Mark W. on October 14, 2008 at 08:20:02:
The crud is in the oil pan, valve train, and inside the block. You can remove the pan, valve cover and head and clean those up, plus the carbon stuck to the pistons. What you want to do will do little if any good, and may even loosen stuff up enough to cause real problems.
