Re: stuck brakes on M
Posted by Janicholson on October 14, 2008 at 18:58:52 from (66.173.50.104):
In Reply to: stuck brakes on M posted by point3dave on October 14, 2008 at 17:42:51:
Put it in 5th gear, clutch out. Jack the rear tires off the ground, and place them on 6X6" blocking so that it is trying to roll off forward. (so the tire is almost touching the ground under the blocks). this puts substantial strain on the flywheel in the normal direction, and can be advantageous. (It also can't go very far if it does move. JimN
