Re: 674 hydraulic problem update
Posted by JimB2 on October 14, 2008 at 19:09:12 from (99.241.179.24):
In Reply to: 674 hydraulic problem update posted by adam59 on October 14, 2008 at 14:33:45:
Hi Adam, to bleed the brakes. There is a bleeder screw on top of each rear axle, looks like a grease zerk.
Require clean bucket and 1/4 or 5/16 inch clear tubing that will fit over bleed screw nipple.
To bleed the brakes run the tractor until the Hytran hydraulic fluid reaches operating temperature.
Run engine at fast idle 1400-1600 RPM, block rear wheels.
1)With tubing connected to nipple on bleed screw and other end in clean bucket, loosen bleed screw and let hydraulic fluid drain until air bubble free, then close bleed screw. Repeat on other brake. Do not pump brakes while bleeding.
Top up hydraulic fluid with fluid caught in bucket, make sure transmission fluid level is full or over full. Also check for leaks by bottom of dash and along top of transmission cover. Brake lines run from under battery box along top of transmission to rear axles.
May have to repeat bleeding and if bleeding only lasts a few days then repost and I will give a procedure to diagnose if it is leaking seals in brake piston.
Re remote lever, center is neutral, down toward foot rest is hi pressure on one remote line and return on the other, up toward 3pt control lever puts hi pressure on the other remote line (was return) and return on the other line (was pressure).
From Bernard who was CIH mechanic for many years:
Hi, may be the unload valve is stuck. Check with engine running, raise the hitch and pull at the same time the remote lever. If the hitch raises, you have dirt in the unload valve. This valve is under the seat and you remove the large plug for access. One trick, loosen the large plug, unload valve, 2 turns and start the engine, the hitch should raise if the valve is stuck. It has a small hole in the valve and just blow dirt out with compressed air. Replace with new O rings.
Bernard le mécano Québec Canada
Re power steering also from Bernard:
Hi TDK, on the 574 tractor, like 74 and 84,85,95 series, it has a Danfoss steering valve. You have to remove all the valve from the tractor and open the valve to change the seal. Some part inside have to be timed, so if you haven't opened a Danfoss valve before, good luck. Best way, take the valve to a CaseIh dealer and ask to change the seal. To install the seal, you need a special tool. Be careful when you remove the steering wheel, don't blow on the shaft with a hammer, remove the wheel with a puller. I have done many seal change when I have worked for CaseIh dealer.
Hope this helps
JimB
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
