shadetree mechanic said: (quoted from post at 10:21:37 10/06/08) I haven't done this in awhile, so I'm trying to remember the specifics. You'll have to remove the plug under the filter on the bottom of the MCV body. I think it takes a 1 1/4" wrench. Remove the plug, then let the spring fall out. There may even be a valve along with the spring. Put the bucket under the hole and start the tractor. After a few seconds, oil will come flowing out. Shut off the engine and put the parts back in the MCV body. When you start the tractor the next time, you should have hyd. pressure. I have to do this every time I change the filter. They say its because the pump is worn and can't prime itself. Hope this helps!
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
