Posted by Gearnut on October 15, 2008 at 12:57:20 from (68.62.56.183):
In Reply to: Bolt patterns posted by mkirsch on October 15, 2008 at 06:23:43:
mkirsch said: (quoted from post at 11:18:38 10/15/08)
I think what you're pretty much going to find is that each "family" or "generation" of engines is going to have its own bolt pattern.
The C248-C281 4-cylinders, for example, will have one bolt pattern.
The C152-C175 4-cylinders, another pattern.
The C113-C153 4-cylinders, again.
The C263-C301 6-cylinder, still another.
The D361-D407...
The D414-D466, and the D312 and D360 "American" diesels...
The D310 and D358 "German" diesels...
Thanks JJ and mkirsch
If it is true that each engine family will have it's own unique bolt pattern, then one could make the logical conclusion that a D361/D407 is different from a DT466, and different from a German engine, which is different from a 263, etc.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
