Posted by tfgarrett on October 15, 2008 at 12:58:44 from (192.208.143.68):
I have a d188 engine just completely rebuilt. It is leaking oil out of the vent tube. I was told to run it under a load to set the rings and it would probably stop, but hasn"t helped. Leaking oil at 2 qts/hour. Could something have been left out in the rebuild? Need help!!!
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
