dr bert, the very late m"s had a different timing cover and the stronger cam gear to accept the live pump. years ago i bought a live pump kit at an auction to add a live pump to an m. had a plate to remove the belly pump and use that as the fluid resevoir. in the mounting instructions, the top outer pump bolt hole was different on the older m. they had you run a bolt in the hole, cut it off flush with the timing cover, file it flat, then redrill a new hole to mount the pump. i have that on my 48 m. did have to change the timing gear a couple years later, tractor has a loader on it, and it was too much strain for the old cam gear. used a super m cam gear. if you still have the old pump, you would be better off to remove the timing cover, put a new cam gear in, and do the drilling and tapping on the workbench,
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
