Posted by Idaho Ron on October 15, 2008 at 17:38:50 from (208.98.173.2):
In Reply to: Touch controll posted by Allan In NE on October 14, 2008 at 17:11:17:
JakeBrakeIH said: (quoted from post at 17:18:46 10/15/08)
I believe I read somewhere in a book that there was a harrow for the C that they made and the Super C's with fast hitchs has a metal rod to be put inplace of the hydraulic cylinder, then you removed the cylinder and used hose extensens with quick couplers and put the cylinder on the harrow...pretty cool I thought.
My tractor will lift anything I put on the back of it but the nose just goes in the air...very outstanding hydraulics for its era...why couldnt you just make new hoses and put quick connects by the back of the seat(provided your cylinder didnt settle, or you could just make a ridged mount for it)...the only thing I would be conserned about would be running out of hydraulic oil if you were using a larger cylinder...Im sure if you were careful you'd be ok...
In my owners manual it shows a roller harrow i think. You take the Hydraulic cylinder off and replace it with a spacer that keeps the draw bar in place. Then you put the cylinder on the harrow to opperate it.
if your cylinder settles you need to make sure the plunger is pushed down. Once the plunger on top is pushed it is "locked" into place. If it still settles then the cylinder needs rebuilt.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
